Nouvelle RX-8 Cosmo II en Suisse
blibop a écrit :
Syngi a écrit :
N'y aurait-il pas alors moyen de modifier nos PCM avec la nouvelle version livrée avec ces évolutions? :??: ... doit bien y avoir un moyen de bidouiller... :siffler:
Et ben bravo, :clap:
tout de suite les mauvaises idées :D
N'essaies-pas de me faire croire que tu n'y a pas pensé... :siffler:
zeno
Message par zeno »
Ils parlent de ca pour japon
RX-8 Sport Prestige Limited II Special Features
Base model
RX-8 Type S (six-speed manual transmission) and RX-8 Type E (four-speed Activematic transmission)
Special equipment
  1. Interior
  2. Exclusive leather & alcantara seats
    Newly added are the sand beige-colored seats made of combined leather and alcantara in the seat's mid-section. The driver's seat is power-adjustable to eight settings and also has a power lumbar support system.
    Also featured:
  3. Exclusive sand beige-colored door trim.
  4. Exclusive black leather-wrapped steering wheel
    The six-speed manual transmission model has a piano black steering wheel spoke panel, and the four-speed Activematic transmission model is equipped with the standard black panel.
  5. There is also a special black-colored leather-wrapped parking brake lever.
  6. Front and rear console lids are sand beige colored trim.
  7. Exclusive shift knob only for the six-speed manual transmission model, designed with an indicator showing black letters and lines with a silver background.
  8. Aluminum pedals are limited to model with the four-speed Activematic transmission model; the six-speed manual transmission model comes with the base model's standard equipment.
  9. Piano black console side bars with a hairline surface.
  10. In-dash six-disc CD changer kit.
  1. Exterior
    The RX-8 Sport Prestige Limited II model also has the following exterior features:
  2. Semi-glossy painted headlight bezels and combination taillight bezels
  3. A change to dark-silver glossy paint for the 18-inch aluminum wheels for the six-speed manual transmission model. The four-speed Activematic transmission model has 18-inch wheels and aluminum rims, rather than the 16-inch size version used before, also featuring a different paint.
  4. A rear lip spoiler
  5. Front foglights are special equipment on the four-speed Activematic transmission model, and the six-speed manual transmission model comes with the base model's standard equipment.
  6. Body Colors
    A total of four exterior trim colors are available: exclusive Copper Red Mica, as well as Snowflake White Pearl Mica, Galaxy Gray Mica and Brilliant Black.
  7. Driving Performance
  8. RX-8 Sport Prestige Limited II comes specially equipped with 225/45R18 tires and aluminum wheels on the four-speed Activematic transmission model, and the six-speed manual transmission model comes with the base model's standard equipment.
  9. Large-size brake discs are installed on the specially equipped four-speed Activematic transmission model, and the six-speed manual transmission model comes with the base model's standard equipment. Large-diameter disc rotor brakes are 323mm wide in the front and 302mm in the rear wheel brakes.
  10. Specially-tuned suspension
    Special large-diameter dampers: the rod diameter has been increased from 12.5mm to 14.0mm and adopted on both front and rear dampers.
  11. Exclusive front suspension cross member
    A Mazda-original technology, this is where the cross member is filled with foamed urethane to provide better handling stability and damping force that mitigates road vibration.
  12. Other new equipment
  13. A water-repellant front windshield, front door window glasses and door mirrors.
  14. A newly adopted advanced card key-type keyless entry & start system (two cards provided) as standard equipment.
j'ai l'ai trouver a Rx8 Owners club qui parle de Mazda Media mais ilya pas un lien
Dernière modification par zeno le 19 oct. 2005, 18:50 PM, modifié 1 fois.
zeno
Message par zeno »
Nouveau clef aussi
blibop
Message par blibop »
Je pensais que tu me connaissais mieux, :ange:
chuis déçu :D
Azmi
Message par Azmi »
Syngi a écrit :
Azmi a écrit :
gana99 a écrit :
la seule chose que je peut confirmer dans le nouveau relooking de la 8 c'est les siege seront en version tout cuir et exit les rayure en PVC actuelle ;)
Oui et elle s'appelera RX8 Cosmo II L en suisse (L = Leather = Cuir).
Mais tu tiens cette info d'où Azmi ? :??:
Ces infos viennent de mon garagiste. :D :D :D
leo69
Message par leo69 »
blibop a écrit :
Moi je tiens ça de Mazda France service client et technique.
Elles seront livrées avec régulateur de vitesse, ce qui ne le rendra malheureusement pas disponible pour les notres ! d'après ce qu'ils m'ont dit, ils ont passé un nouveau faisceau etc, etc... Donc le PCM des notres devrait continuer à être bridé.
Ils vont faire une version du PCM pour les anciennes et une version pour les nouvelles? :oh:
Ca va être l'émeute Image Image Image
Est-ce que le RRC a eu des nouvelles à ce sujet? :hum:
coolyx
Message par coolyx »
Genre...EXACTEMENT CELLE QUE J'AURAIS VOULUE !!!!! :love: :love: :love:
Mais là il s'agit d'une série spéciale... c'est pas la même chose... :??:
bamboo rx-8
Message par bamboo rx-8 »
tres beau cette RX8 mais dommage ecriture en japon :(
il faut voir changement lock ou moteur?
A mon avis les sieges sont trop blanc risque des netoyer tout le temps !!!!! ;)
rx-8 red velocity 231 ch
tony-x
Message par tony-x »
ouf gros sentiment de soulagement, pas de modif ext
Boîte auto :D voilà que mazda veux copier mon Tuscani :D
leo69
Message par leo69 »
Alors en direct de la note de Mazda France à mon garagiste concernant les modifs pour la RX-8 II :
(Ceci n'est valable que pour la FRANCE :oh: )
  • Régulateur de vitesse sur tous les modèles :yeah: :love:
  • Disparition du cuir rainuré des siéges au profit d'un Alcantara/Cuir lisse
  • Alu brossé remplacé par Inox
  • Disparition des coloris Vert et Gris Titanium ( :oh: :oh: ) au profit d'une nouvelle teinte de gris (plus foncée que le titanium...)
    Et j'ai oublié le reste...
    Le tout pour effectivement 300 € de plus :p
Commentaires aprés longue discussion :
  • Régulateur : il n'y a pas de raison que cela ne fonctionne pas sur les anciennes! Il devrait sortir une nouvelle version du PCM avec le retour du régul! :love: :yeah: :love: :yeah: :love: :yeah:
    A ce propos le RRC a-t-il eu des nouvelles de Mazda France? :hum:
  • Il semble que ce soit bien du cuir, la partie rainurée de nos sièges...
    Enfin c'était stipulé comme je l'ai écrit plus haut!
    L'alcantara sera pour l'assise et le dossier, et le cuir sur les bords...
    Attention danger :!: avec les Jean's à boutons, et autres clous!!! L'Alcantara n'aime pas :oups:
  • Alu brossé qui disparaît : il n'a pas su me dire de quoi il s'agissait...
  • Disparition du Vert et surtout du Titanium : ils sont fou chez Mazda!
    C'est la couleur la plus vendue :oups:
Et voilé de l'info vérifiée :siffler:
Concernant le toit auvrant, et les autres options (valables pour toute la gamme Mazda!), il semble que ce soit Mazda qui impose de vendre au moins 10% du parc avec l'option X ou Y!
A l'importateur ensuite de choisir si il la prend ou pas, et donc de s'engager à les vendre...
Par exemple le toit ouvrant n'est dispo de série ( :oups: ) que sur les Mazda 6 break (je sais plus si c'est essence ou diesel!).
Maigre consolation, il n'est pas dispo (même en option, sur le reste de la gamme :p )
Explication plus logique que l'histoire de la taile, mais tout aussi ridicule!
Autre exemple, si vous voulez le GPS sur une Mazda 5, elle sera forcément Diesel!
Option non dispo sur les essences :oups: :oups:
Du coup les codes informatiques ne sont pas créés, et l'importateur ne peut pas passer commande de telle ou telle voiture avec telle ou telle option!
En fin de compte, c'est la faute à l'informatique, comme d'hab :p :p :p
J'adore discuter avec M. Dago :yeah:
[/color]
Azmi
Message par Azmi »
[/color]
Merci pour le complément d'infos. :clap:
Ces infos sont aussi valable pour la Suisse. :salut: :salut:
Et nouvelle couleur Strato Blue en Suisse.
Luc
Message par Luc »
Les sièges sont superbes, avec l'alcantara à troutrous :love:
Par contre, je ne comprends toujours pas l'engouement pour le régulateur, enfin bon... Chacun son truc ;)
Et je veux une white pearl :bouder:
Regulateur c'est la classe mon gars :D
Gaz
Message par Gaz »
C'est le seul moyen de respecter les limitations sur autoroute :)
Par contre bizarre la nouvelle clé :??: Il faut la sortir pour démarrer ou ils ont fait un système "keyless" style transmetteur, ou on peut démarrer en la gardant dans la poche ?
